Only one stripe?
Old Jan 13, 2006 | 10:05 PM
JDJP's Avatar
Default Only one stripe?
Got a 1998 TA automatic, from the code on the door (GU2) it has the 2.73s, with traction control. When I turn the tcs off and do a burnout, only one wheel leaves mark. I would expect both to spin, whats up with that?
JD
Old Jan 13, 2006 | 11:25 PM
86irocz's Avatar
The Auburn differential is probably worn out. How many miles on the car?
Old Jan 14, 2006 | 03:51 PM
JDJP's Avatar
Old Jan 14, 2006 | 03:57 PM
86irocz's Avatar
Change the oil and see what differential you have while the cover is off. Maybe even take a pic, you can also see if there is play in the small spider gears while it's apart.
Old Jan 14, 2006 | 05:27 PM
Carter Hays's Avatar
One wheel peel. time for a diff.
Old Jan 15, 2006 | 07:03 PM
JDJP's Avatar
Thanks for ruining my day...
Old Feb 21, 2006 | 03:37 PM
JDJP's Avatar
So Im going to change my Rear end fluid in the next couple of days.
Im having no problems with the rear except only one wheel spins when I burn out on the road.
Is there anything I would be able to see (not knowing anything about differentials) inside there that could be causing this?
or should I just take it and have it looked at?
Oh also, my speedo is off, and I was told the only way it could be off is if the previous owner changed something in the rear?
