clunk noise and squeak noise???
I had like a POP when I would hit a bump after I put my rear end and LCAs it was just the binding of the LCA it worked itself out. Then I had my reclocation brackets welded on and I had the same POP over bumps.... If that was it make sure you don't have them to tight.. The LCA's should be torqued down with the car on all four wheels.
The squeek could be anything or another part to tight.... I had one but it was my jack and nut wrench rubbing.... on the passenger side of the car.
Good luck
