9" limited slip diff question.
Old Jan 25, 2006 | 12:38 PM
MrDude_1's Avatar
Default 9" limited slip diff question.
ok, i have this limited slip (aka here as a posi) that im buying from a friend.
i THOUGHT i was getting a locker.... but it turns out he didnt know the diff between a locker and a clutch type limited slip, he just thought all limited slips for 9" rears were called lockers.
im not a 9" expert by anymeans.. ive done alot of research on lockers over the last few weeks since thats what i thought i was getting. but i dont know where to start on "posi"s
this is what i have.. how strong is it? my entire rear is "bulletproof", fully aftermarket everything for strength, except this posi..... right now, this is going into a cammed daily driver that sees strip duty... but the car will eventually be boosted into the 600RWHP range, and launched hard at full weight...
basically i want to know if i should buy it and use it for awhile, or back out of the deal.. its a friend and i really dont want to back out of a deal with him, but......
anyhoo hers the pics. click to enlarge. they're huge.
Old Jan 25, 2006 | 01:37 PM
Hawkcmc's Avatar
Beleive that is a trac loc limited slip, common in a lot of fords. Wont hold up to very much and i severely doubt it will last a few launches in the 600's. Its not a locker by any means so I would back out and have him throw it on ebay or something.
CMC
Old Jan 25, 2006 | 01:41 PM
MrDude_1's Avatar
thanks..
anyone know how much this will safely hold? i do have a few other friends that might be able to use it... they're staying n/a for now...
Old Jan 25, 2006 | 01:56 PM
Hawkcmc's Avatar
No dropping the clutch it should hold 450 i would imagine.
CMC
Old Jan 25, 2006 | 03:07 PM
MrDude_1's Avatar
CMC
im alittle confused on your reply.
are you saying it will hold 450 as long as you're not dropping the clutch??
or are you saying:
"no, dropping the clutch, it should hold 450"
Old Jan 25, 2006 | 05:38 PM
Hawkcmc's Avatar
Sorry, if you dont drop the clutch at 5000 rpms then I would imagine the diff should hold atleast 450 maybe a bit more.
CMC
Old Jan 26, 2006 | 10:09 AM
roy's Avatar
roy
That is a 4 pinion Trak Lok . It will take your drag strip abuse if rebuilt right. Will it fail, eventually. Just like everything else .
