whining rear end...
Old Feb 3, 2006 | 02:07 AM
rollinenvy's Avatar
Default whining rear end...
i have a moser 12 bolt and when im on the highway i mainly hear it but its just a high pitched whine, is this normal? if not, any advice?
Old Feb 3, 2006 | 04:11 AM
Nittany_marine's Avatar
how loud is it? Is it on acceleration? Just coasting? Deceleration?
Old Feb 3, 2006 | 11:35 AM
rollinenvy's Avatar
usually cruisin at about 60 and up when i accelerate it goes away which made think it was just the 12 bolt whine people tell me about i just want to make sure because now my rear end feels a little squirrely. but its constant and as soon as i speed up it goes away until i stop accelerating.
Old Feb 4, 2006 | 05:09 AM
EPP's Avatar
EPP
That is fairly common to hear the noise you are referring to, and I wouldn't worry about it. The axles don't use C Clips, so it can't be anything internal giving you the uneasy feeling. I would check to make sure the wheels are still tight, also check the sway bar mounts, and the torque arm bolts. The torque arm bolts need to have loctite applied, as they tend to loosen up. Bob
