HELP! Burnout Question
Is this normal? Am I doing something wrong? Or maybe my tires smell like clutch when they are burned, but I doubt that because I can tell the diference between burnt tires and clutch.
What kind of clutch? Stock or aftermarket
Do you have a line lock or are you foot braking it?
What kind of tires, street, DRs or slicks?
This things will determine how best to do your burnout.
Answers: Stock clutch, No line lock or braking, and Stock tires.
If I was to use the brake what rpm range would I hold the throttle at?
Good Luck
Mark
<small>[ March 19, 2002, 06:43 PM: Message edited by: 1madss ]</small>
