fluid change, how much do I put in?
Old Feb 15, 2006 | 06:14 PM
CamaroSS621's Avatar
Default fluid change, how much do I put in?
changing the fluid in my 12 bolt tonight. How much do I put in? How heavy should I go?
Old Feb 15, 2006 | 06:34 PM
Scott@DrivelineSolutions's Avatar
LS1Tech Sponsor
Buy 3 quarts because you will need to put in 2.5 or so.
Old Feb 15, 2006 | 06:42 PM
thanks. what weight? i was gonna use the royal purple 70-90
Old Feb 15, 2006 | 06:48 PM
LS1Tech Sponsor
Thats a good oil to use. Have you already broke-in the gears? If not use a dyno oil for break-in and then change it out to synthetic.
Old Feb 15, 2006 | 07:05 PM
ive got about 3K miles on the rear so its well broken in. Im really only changing it because I pulled the axles out to replace the wheel studs and decided since im already there to change the fluid. thanks for the info.
