Simple Rearend Question
Old Feb 17, 2006 | 06:38 PM
5.7LoFuN's Avatar
Default Simple Rearend Question
How do i know if i have 3 or 4 channel rearend?
Old Feb 17, 2006 | 07:07 PM
01formulafromthebay's Avatar
If You have (TCS) Traction Control option then You have 4 channel if you just have abs then you have 3 channel.
Old Feb 17, 2006 | 11:29 PM
HavATampa's Avatar
To visually tell by looking at the rearend: if you have wires plugged into a sensor at each end of the axle tube, you have a 4 channel. 3 channel setups have one sensor on top of the pumpkin (diff) and not at the ends of the axle tubes.
Old Feb 20, 2006 | 11:43 PM
5.7LoFuN's Avatar
thanks, i thought i knew the answer....just wanted to make sure.
