How do I remove my stock U joint
Old Mar 23, 2002 | 11:49 AM
highgmc's Avatar
Default How do I remove my stock U joint
Can I do this at home? Do I just beat it out or burn it?
<small>[ March 23, 2002, 11:49 AM: Message edited by: terry99ta ]</small>
Old Mar 23, 2002 | 01:23 PM
WS6Modder's Avatar
Default Re: How do I remove my stock U joint
You really need someone with a press. Supposedly, it can be done by getting the nylon ring hot enough to melt...just take it to a shop...
Old Mar 23, 2002 | 08:13 PM
monSSter1191's Avatar
I went to the local Home Depot and for like $10 picked up a cheapie torch designed for soldering. Simply heat the ends of the driveshaft for a minute or two and the nylon ring they inject inside the ends will come out like a worm. When that is out, hit it a few times with a hammer and it will come right out.
Not worth paying more than $10 to have done. If a shop will do it for free, great, if not, do it yourself. Doesn't take any skill whatsoever - just time.
Old Mar 23, 2002 | 09:25 PM
SS SLP2's Avatar
Becarful when you when you heat up the worm DO NOT stand over the u joint caps some times the grease inside will heat up and blow the cap completly threw a tin wall, after the worm comes out, take a socket large enough to receive the cap put it on the bottom and a small socket (small enough to go threw the drive shaft and drive out the u joint be very carefull and do not damsge the shaft BE VERY carfull
