U Joint question?
Old Feb 23, 2006 | 02:28 PM
BORN2LOSE's Avatar
Default U Joint question?
Is it possible to get dirt inside of the U joint? It was raining really bad one day when I had the Camaro out last summer. The streets were flooded. Ever since that rainy day my car makes a noise as if I were driving on mudder tires. It gets louder as speeds gets higher over 30MPH. I changed my rearend girdle and fluids shortly after and that didn't fix the problem. It also seems louder when its cold out? Anyone have any ideas? I just had my tranny flushed this summer so I don't think its that either. The noise is present when the car is in neutral also at speeds over 30. Thanks for your time.
Oh and one other thing. If it is the U joint how much damage am I doing by driving it still. Its not my daily driver but I have put a few miles on it with that annoying sound.
Old Feb 24, 2006 | 02:37 AM
CW00BlackTA's Avatar
It could be a bad u-joint--although I doubt it was caused by the water. Usually a bad joint creats some vibration that you'll feel in your seat that increses with speed. It doesn't hurt to drive it unless it gets bad enough to fall apart allowing the drive line to fall out. It should really be noticeable then though. Crawl under and see if you have any play in the joints--there should be none.
Old Feb 27, 2006 | 10:48 AM
BORN2LOSE's Avatar
I am not really getting any vibration to feel but I can defintely hear it. Its really bothering me now.
Old Feb 27, 2006 | 12:11 PM
HBHRacing's Avatar
U joints are sealed. Any water that did get inside them would be displaced by teh grease. Either way, a bad U joint won't cause a noise other then a clunk when put in gear.
