need help
Old Feb 23, 2006 | 10:00 PM
BROKEN's Avatar
Default need help
i have a annoying clunk when shift my car its coming somewhere in the rear but i cant figure it out any help would be appricated
Old Feb 24, 2006 | 06:01 AM
EPP's Avatar
EPP
I'll bet that it is your tranmission mount, as they are prone to failure since GM elected to mount the torque arm to the tranmission. Bob
Old Feb 24, 2006 | 09:03 AM
blue01ta's Avatar
Also make sure your lca bolts are tight. Have you had any work done back there lately? If you have that would be a good place to start.
Old Feb 24, 2006 | 11:28 AM
BROKEN's Avatar
no work done ill check the tranny mount thanks for the replys
Old Feb 24, 2006 | 09:36 PM
BROKEN's Avatar
it was the tranny mount thanks for the help
Old Feb 25, 2006 | 06:46 PM
Gregg 00SS's Avatar
Was it noticably broke from looking at it under the car or only noticable once you started taking it off? I'm having similar problems with the clunking and visually checked the tran mount point and it seemed solid with no noticable problems. Guess it might be worth unbolting everything and making sure.
