4.10 problems!
Old Feb 24, 2006 | 07:52 PM
Racafella13's Avatar
Default 4.10 problems!
ok today i was going to put my strange 4.10s in i bought all new bearings etc.. i brought my clutch pak ( LSD CASE ) and stock ring pinion and the new gear and pinion to get the bearings pressed on when i installed it to the pinion is up to high and hits the LSD cover so i took it all out and noticed that the guy at the machine shop put a spacer between th pinion and bearing... i guess the stockone was like that to with the spacer... so is there suppsoed to be a spacer or was i sent the wrong gears??? and does anyone have the papers you get with the gears like the torque specs and stuff the machine shop threw them out..thanks
Old Jun 3, 2006 | 01:54 PM
Black1997T/A's Avatar
Yes You need that spacer. That shim is what deterpines Your pinion depth. You need the exact thickness of spacer You had in there before.
