BIG PROBLEMS WITH SUSPENSION GEOMETRY--->HELP!!!!
Well I went to put my 28X9 slicks on the car and checked the driver side first.The tire went on with no problem other than being close to the lower edge of the rear panel down by the front part of the 1/4 panel.I hammered it until I had a 1in clearance.
Okay so I took the wheel off and put it on the passenger side and it HIT in the same spot but worse like it was really rubbing.So I hammered the lower area away but its still hitting the lower part of the 1/4 panel.Its like my rear is in crook-ed?Could MOSER of welded the control arm mounts on the rear in the wrong place?Is this possible.It looks like threar needs to move back an in on the pass. side?
I ordered adj control arms to correct this but I cant adjust one arm shorter than the other so the tire clears the lower edge of the whell on one side?The car wont track straight?I'm stumped?I dont know what to do.I hope I dont have to take the rear apart and reweld the passenger side control arm mounts on again?
Where do I start as far a measuring the setup
Could it be my unbody being off this much?
I hope not?
I need to hear from some drag racers here who set suspesions up.Guys that really look into setting the cars up properly and straight.I want my car to track true and I'm trying to set the car up for safe racing.
MADMAN ,JAY,COLONEL,BEASST,FIREBALL or anyone else that has had this problem could u give me some advice?
JS
<small>[ March 25, 2002, 08:25 PM: Message edited by: JS ]</small>
Thanx for the help.
JS
