reusing stock 3:42s????
Old Mar 3, 2006 | 11:25 AM
30th t/a's Avatar
Default reusing stock 3:42s????
can you reuse the stock gears? i have 4:10s now but i will be swapping them out for 3:42s and i was going to use my stock original 3:42 but someone said the gear wont line up correct and will whine alot?
Old Mar 3, 2006 | 12:00 PM
mustang93's Avatar
It should be just fine.. A gear is a gear.. Right??
Old Mar 3, 2006 | 02:01 PM
slow trap's Avatar
as long as they are not worn much they should be fine,as long as they are setup properly.
Old Mar 9, 2006 | 07:09 AM
Juiced2000SS's Avatar
I took a set from a 94 Z 3.42's a few years back. Swapped them into my old thirdgen that had richmond 3.73's. I didn't change anything but the fluid, crush collar and pinion nut. No set up, no backlash. They are still going today. Never made a sound.
