Which spline axles?
Old Mar 7, 2006 | 09:18 AM
n2o's Avatar
n2o
Default Which spline axles?
I want to run a t-brake in a 3300lb th400 car. Which axles would do the trick? I am going with a 9inch.
Old Mar 7, 2006 | 11:50 AM
Scott@DrivelineSolutions's Avatar
LS1Tech Sponsor
35 spline and if you want to save some weight have them gun drilled. We are a Moser dealer and we can help order a set if you need.
Old Mar 7, 2006 | 10:42 PM
CW00BlackTA's Avatar
I'm running 31 spline. They are less expensive and are good for around 700 ft-lbs. of torque.
