how much does it generally cost for gears+install
Old Mar 12, 2006 | 09:59 PM
Cchris1109's Avatar
Default how much does it generally cost for gears+install
curious on how much gears+install will usually cost?
if i buy gears myself a shop will install it obviously, do i need anything else to give them??
Old Mar 12, 2006 | 10:05 PM
Z28LS1camaroguy's Avatar
probably around 250-400 dollars, all depends on the shop doing it some do it for cheap and some do it for alot.
Old Mar 12, 2006 | 10:10 PM
Cchris1109's Avatar
yikes, this one shop was telling me 500 i was like no wayyy byee haha now i just gotta find gear shops around my area
Old Mar 12, 2006 | 10:11 PM
Scott@DrivelineSolutions's Avatar
LS1Tech Sponsor
I charge $175.00 labor for a gear install with the axle in the car here in MI.
Old Mar 12, 2006 | 10:14 PM
Cchris1109's Avatar
scott that sounds reasonable, curious what should i bring to a shop if i want gears installed, gear install kit and the gear kit itself? is that it?
Old Mar 12, 2006 | 10:34 PM
keliente's Avatar
Hmm...Rear end FAQ at the top of page covers this...
4. What can I expect to pay for a gear upgrade?
A set of gears themselves will cost $150-$250 depending on what brand you purchase. Most shops will charge $250-$400 in labor, and may add more for supplies. Overall, you will spend $400-$700 on a gear change depending on your location. Don’t skip out and go with the cheapest one – be certain that a trained professional is handling your installation!
10. Besides gears, what do I need for an install?
It is good practice to replace all of the bearings when installing new gears…if you have the rear apart anyway; it only takes extra minutes to replace the bearings. A good master installation kit will include everything you need, but specifically if you choose to replace everything you will need: carrier bearings (2), front pinion bearing, rear pinion bearing, crush sleeve, pinion nut, axle bearings (2), axle seals (2), pinion seal, a set of shims, gear paint, loctite, RTV gasket maker, 75w90 (2), GM rear end additive (for LSDs). It is also a good idea to replace the ring gear bolts, which may stretch over time. They are left hand thread, fyi.
Old Mar 12, 2006 | 10:37 PM
Cchris1109's Avatar
crap i feel dumb, blonde moment ha
i usually read the stickys didnt think every area had one heh!
also found out i have 3.23 gears, curious if i need anything else for 4.10s
Old Mar 14, 2006 | 11:15 AM
ws6formula98's Avatar
i payed 840 for the gears, TA gidler, install at Azpowerand sound...they do a good jod there..
Old Mar 14, 2006 | 01:37 PM
urshtwk's Avatar
[B]I have a friend that works at West Coast Diff, he can get 4.10s for aroun 120.00 and he said he would only charge me 100.00 for labor!
NOW THATS A STEAL!!
Old Mar 14, 2006 | 05:17 PM
FUN LS1's Avatar
Yeah, you'll want a grinder to take off about 1/8" on the corner of the paddle block (no problem), or spend $175 for the 4.10 paddles.
Old Mar 14, 2006 | 05:34 PM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
About 500.00 if the shop provides the parts.
