4.10's in a 10 bolt
http://cgi.ebay.com/ebaymotors/Camar...QQcmdZViewItem
it says 3.08 and lower, so will this not work?
The eBay auction link did not pull up.
that you can buy that will work with 4.10. from what I remeber it wasn't cheap(150.00 i think but it's been a long time)
the ebay link appear to be a kit to allow you to run(thin/3series) gears on a 2 series carrier. instead of the 2 series/thick gearsets.
your problem doesn't seem to be whether you have 2 or 3 series but the problem that the pinion to ring gear ratio of 4.10 is different than 3.42's and it causes the paddle pin to hit the teeth.
