what is this part of the gears called? mine is missing.
Old Apr 2, 2006 | 11:48 AM
Donohue96M6Z28's Avatar
Default what is this part of the gears called? mine is missing.
well ij ust bought some used gears from someone and i came to realize that it is missing this part. Can it be replaced or did i just buy some gears taht arent usable?
Old Apr 2, 2006 | 12:18 PM
bowtieman81's Avatar
That is the pinion bearing, and it is replaceable.
However, those gears you have in the pics look pretty corroded (maybe its just the pic). Not sure I would use someting like that.
Old Apr 2, 2006 | 12:23 PM
lol those arent the gears that i have bc those gears have the pinion bearing, mine dont and i would never put gears like that in my car. the ones that i bought, the guy said only had 748 miles on them and they look perfect.
thanks for the help.
Old Apr 2, 2006 | 02:05 PM
roy's Avatar
roy
Don't forget the the Solid pinion spacer or crush sleeve, pinion nut and new pinion seal. WTH, just order a differential kit with it all. it probably cheaper
Old Apr 3, 2006 | 11:54 AM
LOL, I was hoping you were not putting those in your car.
Anyway, Roy may be right about just buying a diff kit. You might look into that.
