Pinion shims
Old Apr 3, 2006 | 10:14 AM
toretto's Avatar
Default Pinion shims
generally speaking, how thick of a shim[s] do you guys use on the pinion gear? or how thick do you guys generally start off with?
this is of course for the 7.5" 10 bolt.
Old Apr 3, 2006 | 10:30 AM
1fastWS6's Avatar
Start by using the shim that came out of the rear originally.
Old Apr 3, 2006 | 10:52 AM
toretto's Avatar
thats the problem. i'm helping a buid re build his. and his pinion gear didn't have any! the bearing was spaced out!
turns out the car had 3.73s. thats explains why his speedo was all off.
Old Apr 3, 2006 | 11:44 AM
1fastWS6's Avatar
try a .023" then just for starters
Old Apr 3, 2006 | 12:13 PM
Scott@DrivelineSolutions's Avatar
LS1Tech Sponsor
What ratio, gear manufacture, new or used bearings? I need more information to help with a pinion shim selection.
Old Apr 3, 2006 | 12:32 PM
toretto's Avatar
Well we're putting in a used set of stock 3.23s with used bearings since they are fine. and the races have no scratches or anything.
