Moser 9" and ABS "only"???
Old Apr 17, 2002 | 09:52 PM
Jax White TA's Avatar
Default Moser 9" and ABS "only"???
Is there ANY way? Can you splice the wires? Can you get a 4 channel ABS unit and use the reluctors on the axles? There has got to be a way. Please. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
<small>[ April 17, 2002, 09:53 PM: Message edited by: Jax White TA ]</small>
Old Apr 18, 2002 | 12:02 AM
rich's Avatar
Default Re: Moser 9" and ABS "only"???
I just bought a moser 9" with abs and traction control. I got it used offf the classifieds 35 spline locker aluminum center lca lowering brackets 1350 bilet yoke. he said he payed $2800 with a heat treated 3.90 gear.hears their # 219-726-6689
Old Apr 18, 2002 | 06:57 AM
Thanks, but as I said in the topic, I want it setup for ABS "only". If you dont have TCS, your reluctor ring is part of the carrier, if you have TCS, you have a reluctor ring at each axle on the outside. Moser can do the reluctors on the axles, but not on the carrier. Also, TCS ABS is 4 channel, meaning 4 sensors. Non-TCS cars have a 3 channel ABS controller. Theres got to be a way to do it.
Dan
Old Apr 18, 2002 | 11:59 AM
WILWAXU's Avatar
Nope. No abs only 9" setup.
12 Bolts are plenty strong.
