anyone using a t/a rear girdle?
Old Apr 20, 2006 | 11:06 PM
slow2000z28's Avatar
Default anyone using a t/a rear girdle?
i just bought a t/a girdle for my 4.10 setup and i was wondering what, if anything, the girdle will effect.
Old Apr 21, 2006 | 09:18 PM
nelson1100's Avatar
Default It's supposed
to put pressure on your cap bearings to prevent the bolts from backing out and aluminum gets rid if heat faster than steel.
also look into a solid pinion spacer instead of the crush collar,
Nelson.
Old Apr 22, 2006 | 07:18 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
The TA girdle is a great piece and worth the money
Old Apr 23, 2006 | 10:19 AM
culhan9's Avatar
I've got one... Might add it looks good too!
Old Apr 23, 2006 | 12:19 PM
8a8mfh's Avatar
It's purpose is not to prevent the bolts from backing out, it's to prevent carrier bearing cap deflection.
Old Apr 24, 2006 | 02:54 PM
Zepher's Avatar
I thought all it did was enhance the bling factor when you are working under the car?
btw, I have one as well.
By Brett Foote | 2026-06-04 05:00:17
