moser problems
Old May 7, 2006 | 01:17 PM
RA4926's Avatar
Default moser problems
installed my moser last weekend. ive got the 12 bolt with truetrac and 33 spline axles.when i was puting the axles in i noticed that the left side bearing wasnt sitting flush with the end of the housing, i didnt think anything of it cause it sucked in when i torqued on the backing plate. ive had some nasty vibration on the highway at 70 on up. took a look at both axle bearing and the right side looks fine but the left side, the inner race on the bearing is where it was pressed onto but the black weatherseal and the outer race is about a big 1/8 inch in from the inner race. dont know what the hell is going on...is the housing to short on the left side or is that normal and i got a bad bearing?? also i have the normal gear whine but when i am coasting from 40 and lower i get a clunking sound. it isnt completely constant but it sounds speed sensitive. also when everything is torqued and the car is on the ground i can grab the top back of the wheel and pull outwards and get a clunk sound when i pull. ive taken the cover off and had someone pull on the top of the wheel, through the one hole on each side i can see the axle moving up and down a little but the i dont notice the gears or truetrac moving. i dont know what the hell is goin on ANY help would be greatly appreciated
Old May 8, 2006 | 02:08 AM
Carter Hays's Avatar
Contact Moser make them take care of you.
Old May 8, 2006 | 05:14 AM
EPP's Avatar
EPP
If I remember correctly, you purchased your Moser rear directly from Moser. Give them a call and tell them what it is doing, they will help you out. Bob
