strange 12 bolt or 9"
Old Apr 29, 2002 | 06:10 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Re: strange 12 bolt or 9"
- 9 inch setups weigh more
- 9 inch setups are typically cheaper
- 9 inch has removable center section
- 9 inch does not really have provision for ABS that I know of
I'd say 12 bolt works for most folks. I'd get the 800 lb HD clutch packs if you go Strange. Call Geoff at Strange to get his thoughts, and call early... 847-869-7010
Old Apr 29, 2002 | 07:49 PM
Freak's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Pro Stock John:
<strong>- 9 inch does not really have provision for ABS that I know of
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">It depends on which setup you have, if you have ASR then you can get a Moser with the ABS, but if you dont you cant get the ABS from what I understand.
Let me add to PSJ's list
9 inch is stronger
9 inch takes a few more hp to turn
9 inch has more gear ratios readily available from what I have seen. One website I went to had 55 different gear ratios from 2.84 to 7.0 available. Not custom gearsets mind you, they were all standard parts.
Old Apr 30, 2002 | 12:00 AM
DriveATransAm's Avatar
Default strange 12 bolt or 9"
long as everyones asking rearend questions- whats the major difference between the two? will the 9" soak up more hp and reduce ets by itself? hows the 9" bolt up compared to a strange, and whats a 9" cost in comparison?
