Need Help! Hey guys, I have a 2000 z28 as well as a thirdgen. I bought a 4.10 ring and pinion for my thirdgen but the car is now up for sale. The gear is still new in the box. I was wondering if anyone knows if the 7.5" GM 10 bolt 4.10 for the thirdgen can be used in my ls1. The only differences are the splines when looking at new gears for the ls1 and the thirdgen. the ls1 has 28, whereas the thirdgen has 26 (or viceversa, i forgot which is which). Will the gear fit and work right in my ls1? Thanks in advance! |
anyone? |
Spilnes are in the carrier not the gears. 7.5" ring and pinion will fit any 7.5" in camaro, firebird (f-body) monte carlo, cutlass, skylark (G-body) and "S" series truck. S-10 & S15 you just have to know what series carrier the gears are for. |
the gears i have are for a 3-series carrier...will this work? |
My car is an A4. Here's the exact details of each ring and pinion. I just need to know if the thirdgen ring and pinion will fit and work properly in the ls1 because i already have the gears, no sense in buying new ones if i have these already. Thirdgen Ring and Pinion AXLE INFO REAR - GM 10 BOLT 7.5" - 26 SPLINE AXLES AXLE POSITION REAR PINION TYPE STANDARD COVER BOLTS 10.0 AXLE SPLINE COUNT 26.0 RATIO TO USE LOW RATIO CASE 3.23 RING GEAR DIAMETER 7.63 PINION SHAFT DIAMETER 1.44 RING GEAR BOLT QTY - SIZE 10 - 3/8in x 18 thread PINION SPLINES 27.0 LS1 Ring and Pinion AXLE INFO REAR - GM 10 BOLT 7.6" - 28 SPLINE AXLES AXLE POSITION REAR PINION TYPE STANDARD COVER BOLTS 10.0 AXLE SPLINE COUNT 28.0 RATIO TO USE LOW RATIO CASE 3.23 RING GEAR DIAMETER 7.63 PINION SHAFT DIAMETER 1.44 RING GEAR BOLT QTY - SIZE 10 - 3/8in x 18 thread PINION SPLINES 27.0 Thanks for you help |
anyone have any ideas? |
t t t |
if your 4th gen has 2.73 now, no they wont fit. IF you have 3.23's or 3.42 they will fit |
ok, thanks alot |
© 2024 MH Sub I, LLC dba Internet Brands
