How to install a 12 bolt?
Old May 25, 2006 | 11:24 PM
keliente's Avatar
Default How to install a 12 bolt?
Let's begin by admiring our beautiful 12 bolt.
Rottie not included
To start, commence the usual setup process. Block the front wheels, and jack the rear of the car high in the air. Use a jackstand under each side of the rear subframe rails for the main supports, and then later use 2 more jackstands under the 10 bolt axle tubes to support it for removal. If you opted to buy new backing plates and reluctor rings from Moser, you can remove the rear end without taking the cover or axles off. Remove the wheels. The calipers and hangers can come off together, they are held on with two 15mm bolts on each side. It is not necessary to disconnect the calipers to install the 12 bolt, but be careful not to stress/break the caliper’s lines. I simply used a bungee cord to hold the caliper to a hole in the body.
Caliper hanging with a bungee cord
With the caliper out of the way, the rotors pull off if you didn’t forget to release your e-brake. To remove the backing plate the axle will need to come out first. Remove the rear cover and let the fluid drain into a receptacle. Rotate the carrier until you see a small 8mm bolt. Depending on your car, it will either have a Torsen rear end (identifiable by the paddle) or an Auburn (which uses an axle pin). Either will slide out when the bolt is removed. If you have a car with ASR, you will need to remove the rear speed sensors from the backing plate, each held on with a 10mm bolt. Then push each axle towards the middle of the car and the c-clip should jingle jangle to the bottom of the housing. After that, the axles can be pulled out.
Removing axle pin bolt on an Auburn carrier
Your rear without the backing plate
If you have ASR, this would be a good time to verify that your wheel speed sensors will fit your new rear end. Obviously the hole in the backing plate is large enough, but often there are clearance problems with the axle tubes. It may take a little bit of grinding to get the sensors to slide in, so grit your teeth, grab hold of that grinder, and start taking away material off your $2k+ investment. I did it while the axle was in the car simply because I didn’t have the foresight to do it beforehand.
Take a small bit of material away to fit the sensor
Now we can commence the actual removing of the 10 bolt. There are a few ways to go about this as far as removal of components go, but here’s the rundown of what worked for me.
First a large jack was placed squarely under the rear end, with a slight bit of pressure on it. It would behoove you to remove the caliper’s brake lines and any traction control wiring from the rear end first, so it doesn’t get hung up on something later. The brake lines are held on mainly by little clips that need to be bent out of the way. Towards the front of the rear there is also a small bolt pinning the lines to the rear end, that must come out too.
Place the jack under the rear, towards the front
Remove the 13mm bolt attaching the brake lines to the rear
Now the brake lines are free to hang
To remove the e-brake cables from the bracket, take a pair of pliers and depress the tabs until it pops out backwards. Slide it back so that the thin, spring-encased part will slip through the small opening in the bracket, and pull it out. From there you can slip the e-brake cable out of anything else that secures it to the rear, then let it dangle freely. The e-brake bracket’s bolts can be removed, and the bracket can be tied out of the way.
E-brake cable assembly
Pinch the prongs to remove the cable from the bracket
When everything brake & electrical wise disconnected, the torque arm bolts were removed at the rear end. If you disconnect the torque arm before anything else, it lessens the chance of binding up the bolts later on. With the jack firmly under the torque arm, remove the nuts from the bolts. If they do not easily slide out the top, play around with pumping up/lowering the jack slightly to get it angled just so.
Remove the torque arm nuts, and slip the bolts out
With the torque arm out of the way, you can go to town on the sway bar end-links, lower control arms, and shocks. The control arms can stay mounted to the body, just remove them from the rear end.
The shock's nut is 21mm. When the nut is off, push the shock out of the rear end and let it hang
Swaybar endlinks are 14mm, remove these as well
Remove the LCA from the rear but leave it attached at the body
keliente's Avatar
Now do a final once-over to make sure nothing is still attached before attempting to remove the rear end.
This next section is open to any ideas you may have as to what will be the most effective way for you to remove the rear end from the car. If you have a buddy you can simply lower it down and lift it out of the way. If you’re up on a lift you could use a transmission jack. I did my install solo, so I had to get a little creative. It also doesn’t help that my arms are better suited for lifting cookie sheets out of the oven instead of heavy chunks of metal (see, women can make ‘get back in the kitchen’ jokes too!) I used the jack stands to support the rear and lowered them a few notches so the rear could slide out from under the car. I then dragged the rear end out from under the car (looked something like a lion dragging a zebra across the savanna).
Now you see it
Now you don't. Who needs David Blaine when you have Keliente?
Once you have the rear end out of the car, notice where the hole for the brake line clip is towards the front of the 10 bolt. Make a few measurements and drill a similarly sized hole in your 12 bolt. You can either tap that hole and reuse the bolt, or slip a nut & bolt through it to retain the clip. Please disregard the fact that I put two holes in my 12 bolt in an attempt to perform this procedure. I got the old saying, ‘measure twice, cut once’ backwards!
Drilling a hole for the brake lines
If you would like to add fluid to the 12 bolt, now would be a good time. The fill hole is in the same location as stock. Otherwise it should be ready to bolt in. I also took the time to clean up the driveshaft tunnel/rear underneath of the car which had been showered with gear oil from an omnipresent pinion seal leak.
Now you can get your 12 bolt up onto jackstands, a jack, or in your buddy’s hands, and proceed to put it beneath the car. Line it up so that it is fairly close to where it needs to be. The rear components can be re-installed in whatever way is best for you. I positioned the rear as close to the torque arm as possible, and installed those bolts first. Be sure to use loctite on the torque arm bolts. If you decided to switch to an aftermarket torque arm, you will need longer bolts than what Moser supplies.
12 bolt lined up
Moser leaves a tapped hole with a barbed fitting in the top of the axle tube. You’ll need to get a slim piece of tubing and attach it to the chassis somewhere (leaving room for suspension travel). It is a vent tube, and if you don’t secure it properly you will lose fluid out of it.
From here the installation is all downhill. Reconnect the shocks and swaybar endlinks, as well as the control arms. When tightening the control arms, load the suspension. If not, you may experience some popping noises while driving.
Almost there!
Reinstalling the brake lines is rather simple. Bolt the small bracket to the front of the housing, and secure the metal brake lines to the rear in an appropriate manner. For the e-brake cables, you can reuse the metal holders from the 10 bolt (that are inserted in between the rear cover and the rear cover bolts). Slip the e-brake cable back through the hole and bend the prongs slightly so it does not want to slip back out. Attach it to the backing plate. When you first pull the e-brake again don’t panic when it comes all the way up, it is self-adjusting.
Reattaching the brake lines
E-brake cable back in place
If you have ASR, secure the wiring harness so it will not get torn up. I attached mine to the brake line. Reconnect the connectors to the sensors.
Reinstall sensors
To use your sway bar on your new 12 bolt, you will need to pick up a set of 3" exhaust clamps. If you opted for the thick aluminum cover you may have to get a little creative for the sway bar to fit over it.
Exhaust clamps attaching sway bar
Now do a final check - tighten/check all of the bolts, make sure the fluid is topped off, and that the brake lines are secured. Reinstall the rotors, then the calipers & hangers, and finally the wheels. Leave the car on jackstands and now you can proceed to ‘break in’ the rear end as specified by Moser. They recommend letting the car freewheel in a forward as well as a reverse gear for a few minutes each. Recheck the fluid afterwards, and take it for a test drive. Once driving, Moser recommends accelerating/decelerating a few times, and then allowing the gears to cool fully before driving again.
Success!
Old May 26, 2006 | 05:08 AM
Carter Hays's Avatar
I worked with an ASE Master L1 tech at a Porsche/Audi dealer, and she always beat the book!! She banked major $$$ with electrical/under the dash type work.. My forearms looked like I had been through a meat grinder most days. In fact most jobs took me days
Nice write up and great pics.
Old May 26, 2006 | 06:51 AM
HartAttack's Avatar
nice writeup...very helpful!
Old May 26, 2006 | 07:26 AM
alamantia's Avatar
I just drilled & taped two more holes in my 10-bolt and converted it into a 12-bolt, much easier and cheeper
Old May 26, 2006 | 08:08 AM
keliente's Avatar
Old May 26, 2006 | 08:25 AM
alamantia's Avatar
All you suckas out there are payin too much, ship me your 10-bolt and I will convert it for just $999.00 it comes with a warrenty of 59' only void if used on a LS1, LT1, L98, LG4, 3800 and also in 50 states.
Old Apr 30, 2007 | 03:56 PM
ROCNDAV's Avatar
Keliente this should be a sticky. I'm always having to search for your post when someone asks a question about installing a 12 bolt
Old May 1, 2007 | 03:25 PM
SheaMus's Avatar
thanks again for a great write up
Old May 5, 2007 | 11:50 PM
Breaking Stuff's Avatar
This should definately be a sticky.
Old Sep 22, 2007 | 12:11 AM
bearcatt's Avatar
Good write-up. I need to get one of those 12 bolts soon.
Old Sep 22, 2007 | 06:43 AM
Billiumss's Avatar
Great right up, should help with my install of my 9"
Old Nov 4, 2007 | 07:15 PM
sdbrown84's Avatar
Any mods sticky this yet?
Old Nov 4, 2007 | 07:45 PM
ApexVIII's Avatar
nice write up i wish i had the money for a 12 bolt lol
Old Nov 5, 2007 | 11:07 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Brings back Memories..... x2
Old Nov 5, 2007 | 07:37 PM
HMFDZ28's Avatar
Wait a min.....I thought the Rottie was required for the swap????? Now what am I gonna do with this extra "Part" laying around....litterally.
Nice write up yet again Kelly, you are the woman!
Old Nov 5, 2007 | 08:20 PM
keliente's Avatar
That's your anti theft device for your new rear. Protect your investment.
Old Feb 15, 2008 | 11:43 PM
Red96TA's Avatar
feels sticky
Old May 17, 2010 | 08:10 AM
BRD-PREY's Avatar
It is much less stress on the mind if you grind just small flat in the TCS/ABS sensor. Just remove a small amount of material opposite from the metal clamp. Then install it with this toward the axle and then you can rotate into the correct postion when it gets into the relief already ground by moser.
Ed
Old May 17, 2010 | 08:51 AM
bww3588's Avatar
way to bring back a 2 year old thread.....i think Kelly fell off the face of the earth, havent seen her posting here in years.
