Dropping a Ford-9 Question
Old May 8, 2002 | 08:44 PM
Gold Phoenix's Avatar
Default Dropping a Ford-9 Question
How well does the Moser Ford-9 drop in the F-body? Do I need to get a custom driveshaft? Since I am on the same subject, how about the Moser 12-bolt?
Old May 8, 2002 | 10:14 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Re: Dropping a Ford-9 Question
It bolts right in... I had to cut the E-brake brackets that hold the cable, and change the ujoint.
Old May 8, 2002 | 10:15 PM
LS1Tech Co-Founder
Old May 9, 2002 | 04:53 PM
CoopDog's Avatar
The brake backing plates need to be machined to fit over the axle bearing which sticks out of the axle end slightly, I think it was an eighth of an inch. Other than that, fits pretty well.
