9" Moser - noise on slow turns
My problem - just this week I noticed when driving through my parking garage at work that I could hear an odd squeek/thumping when turning left slowly - seems to come from the drivers side but hard to tell. I thought I had a flat at first but obviously that is not the problem. I also noticed when I take off hard from a stop and turn either left or right that my wheels want to hop, which doesn't feel right to me.
I've been searching and it seems like I might have a bad axle bearing(s)? Could it be more than that? What happens if an axle bearing goes out?
Since it was completely built out before I installed it I am not familiar with how the axles get put together. Need help with diagnosing/fixing this...please!
I do notice that the wheels wants to hop on either left or right turns - basically if I gas it from a stop and turn either left or right (inducing a slide) it wants to hop a bit first...maybe that part is "normal" for the TrueTrac?
And it isn't so much a winding noise...it is really a kinda squeeky thumpa thumpa sound (very hard to describe)...it is not really metalic sounding but is more like a flat tire (rubbery thumpa thumpa?).
Here's another tidbit that could be related...whenever I reinstalled my springs/shocks I got something goofy because when I hit a hard bump it sounds like I'm bottoming out (only big or sudden bumps do this). I think that is relatively common if you get them put in the wrong direction (?) and I plan to readjust the springs in the near future but for now I'm just going very slow over known bumps.
That bottoming out I also have that problem and I figured out that it is my torque arm bracket hitting the floor pan, I haven't got around to it yet but i'm just gonna beat in that part of the floor pan a little with a BFH.
But the turning thing, definately find out if it's only on left turns because I was never able to hear anything on right turns when I was messing around with it. The TruTrac does not make any noise and it shouldn't, if you hear anything coming from back there it is a problem, mine makes no noise at all right now, not even with the steering locked and parking.
Stupid question time - when I pull the axle, which side do I grind? Any idea if there is any pictures of the axle that I can see before I pull it out?
I guess I will have to give it a shot on Saturday AM. I'll let you know if it seems to help - thanks for the feedback!
http://cgi.ebay.com/9-FORD-MOSER-AXL...QQcmdZViewItem
Let me know if you have any questions.
One more question - do I have to drain the oil first? I assume I will have to but since it was all put together originally I just filled her up and bolted it on so I wanted to double check (don't want to mess with it if I don't have to).
I will let you know how it goes...thanks again!
I'm still going to try pulling the driver side and grind it down to see if it helps but I'm not sure what to think now. Maybe it is pushing on the entire assembly? I wish I could isolate the sound...when I turned right I couldn't tell if the sound moved or not.
When I pulled the axle I noticed that the axle bearing had grease that appeared to squirt out of the differential side (it looked like it had been pushed out to some degree). After reinstalling I took it for a spin and noticed I still had the "thumpa" sound but it seemed like it was only on left turns. So do you think my axle bearing is already shot? It seems like it to me...
When I replace it, will I have to have it pressed onto the axle I can I get it on there any other way?
How close is your exhaust to the driveshaft? Get the car on jack stands and load the suspension by jacking up on the rear end until it barely lifts it off the stands and see how much clearance you have, if you are as close as mine was when I first installed mine, when I went to turn a certain way and was in first gear and would push in the clutch, my driveshaft would hit the exhaust just barely.
If the bearing seems ok I wouldn't replace it, it's like a $60 bearing. Only other thing I can think of is to make sure your brake backing plates are bolted all the way to the housing, if the axles are moving in and out it could make that noise on a turn. Are you lowered? Are you sure it's not something else hitting like the tires rubbing etc?
If you do end up replacing that bearing, yes you have to have it pressed, you might be able to manage it with the right size pole and a hammer but I wouldn't recommend it. The press fit from that bearing and it's press ring above it is all that holds your axle in there, if done incorrectly and somehow that bearing manages to come off the axle, you could really do some damage.
By sealed...does that mean that no grease should have gotten out of it? It definitely looked like the grease was "squeezed" out on the differential side of bearing...it left a bunch on the tube and there was more left on the seal of the bearing itself. I debated prying it open and trying to pack more into it but didn't. I tried spinning it and it did spin without grinding but it seemed like it took a little bit of effort to do it - I expected it to just turn real easily.
http://home.kc.rr.com/kcrickss/camar..._end_noise.wav
or
http://home.kc.rr.com/kcrickss/camar..._end_noise.mp3
Ideas anyone? I'm beginning to wonder if this is an axle bearing or something else altogether. I do hear a small bit of similar "squeek" when turning right but it is not nearly as noticeable or loud. I don't hear anything at higher speeds or large radius turns (a medium/large size intersection left turn doesn't seem to do it).
I think this all started after my first hard romp on it this past week too - rowed through 2-4 gear shifting relatively hard.
