Inspecting Rear
Old May 19, 2002 | 05:16 PM
Skipp's Avatar
Default Inspecting Rear
I plan to inspect the rear to see what is wrong with it. Once I get the cover open, will I need to take anything out of the housing, or should I be able to visually inspect without taking anything out? Also, should I clean any of the parts off before putting the cover back on?
Old May 19, 2002 | 09:50 PM
Skipp's Avatar
Default Re: Inspecting Rear
I've got the cover off the rearend. What else am I needing to do, and what should I be looking for? Attempting to determine the cause of this gear whine. All help appreciated.
Old May 20, 2002 | 09:00 AM
Ragtop 99's Avatar
Gear whine is frequently caused by a slight mis-alignment of the parts (e.g. a few thousandths misalignment). You probably will not be able to see that on a simple inspection; it take a fairly substantial diasassembly to fix it.
If the whine isn't real bad, heavier gear oil often helps quite it down.
