Result of rearend check
Old May 20, 2002 | 01:01 AM
Skipp's Avatar
Default Result of rearend check
Tonight, pulled cover off differential housing to check for any obvious signs of broken parts. From what I could tell, nothing appears to be broken. But, am curious about the pattern on the gears. Could this be the source of the gear whine? I still don't know what the hell is causing the jerking and clunking. I do have some digital pics that I took, but can't seem to figure out how to post them on here.
Old May 20, 2002 | 02:29 AM
Skipp's Avatar
Default Re: Result of rearend check
Went ahead and left the cover off for right now. Should I check anything else before putting the cover back on? I did not remove anything inside the housing. Just did a visual inspection, didn't think it was necessary to take anything out. Nonetheless worried there might be something I couldn't see.
