Tranny maintenance Qs
Old May 20, 2002 | 05:20 PM
quickWS6's Avatar
Default Tranny maintenance Qs
I'm about to change my auto tranny fluid & filter. I want to change it to Royal Purple. How much fluid does it hold? Where can I get the correct filter? I also want to add a pan with a drain plug and cooling fins. What is a good one? Preferably not one too much lower than stock. Would an aluminum one help with weight much? Thanks a lot!
Old May 21, 2002 | 08:49 AM
02BlkWS6's Avatar
Default Re: Tranny maintenance Qs
I do not have enough miles on my 02 WS6 yet to have gone through the process but have seen some threads about GM posi additive.
What's the additive all about?
<img border="0" alt="[Firebird]" title="" src="graemlins/formula.gif" />
Old May 21, 2002 | 08:52 AM
02BlkWS6's Avatar
Sorry, it appears the additive is related to the rear end fluid. <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" />
Old May 21, 2002 | 09:31 AM
Superman's Avatar
Royal purple.. oooh that could get expensive. You won`t be able to get all the fluid changed since most of it will be left in the converter and such. I believe only a 1/3 of the fluid will come out of the trans pan.
I`d say you`re better of with just regular dino trans fluid and more changes. A nice alternartive to the expensive deep trans pans is the truck pan. No fins but how much cooling can those really give ya?? Comes with a drain too and it`s not low. No weight saving over there either... get the filter at any auto parts store.
