Popping out of third
I believe only 99 and 00 tho
Check this out and see:
http://www.alldata.com
<img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
<strong>thank you
i do not know what have of that means but thank you.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The synchronizers on 3rd gear. GM has acknowledged a problem with the 6 speed trannies and is replacing the 3rd gear synch's and the shift forks.
Take your car to the dealer and let them either replace your tranny, or replace the 3rd and 4th shift forks, synch's and blocking rings.
Go to All Data.com and print off the TSB # (technical service bulletin) this way the dealer knows you know......it's been recalled!
Maybe you messed it up mashing it into 3rd? Usually when a clutch does not dis-engage it blocks you from putting it into gear? This happended to me on the track so I know my clutch is on the way out.
Goodluck dude.
Here is the link the to AllData page showing the TSB(?) number for 2000 Firebird:
http://www.alldata.com/TSB/48/004802IS.html
01-07-29-003A MAY 01 M/T - Jumps Out Of Third Gear
I guess it's time to head for the local Pontiac dealership <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" />
