10-bolt solid crush sleeve?
Old Jun 24, 2002 | 02:27 AM
ZR2877's Avatar
Default Re: 10-bolt solid crush sleeve?
? Has any body else installed new gears in a M6 and had a weird whistle or whining noise come from where the shifter is just got mine done and its loud im sure its not the rear gear whining because its only when you barely touch the gas peddle in 4th,5th, and 6th gets louder the faster you go maybe drive shaft or something no noise when coasting in neutral.
Old Dec 19, 2002 | 07:27 PM
Dom's Avatar
Dom
Does any one have a detailed pic of the solid crush sleeve? Since the regular crush sleeve is like a spring keeping pressure on the bearing as it wears, does the solid one have the same function, just does it better?
