9 inch q's
Old Jul 11, 2006 | 08:10 PM
allthrotle's Avatar
Default 9 inch q's
I bought a 35 spline detroit locker and a strange nodular iron pro series third member for 9in. my problem is the detroit locker housing is hitting the pinion support on the third member. Has anyone had this problem setting up their 9 inches? I know the detroit locker is for a 9 inch as well.
Old Jul 11, 2006 | 11:17 PM
Scott@DrivelineSolutions's Avatar
LS1Tech Sponsor
Get the die grinder out, it wont hurt anything if you take minimal material off.
Old Jul 11, 2006 | 11:54 PM
allthrotle's Avatar
I would take the die grinder to it but theres so much hitting If ground it down to make it fit there would be nothing left of the pinion support. otherwise I would of. I know that the carrier bearings are the right size and the case is the right size to. Im not sure what else to do?
Old Jul 12, 2006 | 10:59 AM
LS1Tech Sponsor
I have built many of these with Strange castings, are you using a different manufacture case? HRW, Moser, etc.
Maybe take a pic for me to see.
