9 inch problem?
Old Jul 13, 2006 | 11:27 AM
stupid10bolt's Avatar
Default 9 inch problem?
I know there have been similiar threads on this but here goes anyways. I have the moser 9" with truetrac diff. It seems to make noise on left or right turns, like a whineing noise but only when really going slow. Also when i slowdown almost to a complete stop(i can notice this in neutral quite a bit) it makes a thumping sound and a few other strange noises. Is it not normal at all for the truetrac to make noises? I figured it was just part of the rear setup.
Old Jul 13, 2006 | 08:47 PM
Scott@DrivelineSolutions's Avatar
LS1Tech Sponsor
Did Moser assemble it? You need to double check and see if the driver side axle is running into the washer inside the diff. This has been a common with the preloaded Turetrac's and Moser has not allowed enough clearance for that unit. I have seen exploded axle bearings cause the backing plate is loading the bearing.
Old Jul 14, 2006 | 02:09 AM
Yes i ordered it from DLS and its a moser unit. Had a feller in a shop around town here install it for me and now its makeing what i described as a whineing noise on turns, and it's very "creaky" sounding over speed bumps and when i slow down etc.
Old Jul 14, 2006 | 05:06 PM
SS4Matt's Avatar
mine makes some of those same noises...the "bird chirping" squeeky noise on sharp "michigan U-ey's" has gone away...but i still get that woop wooooop wooooop sounds if im coasting in neutral to a stop from say 10mph or so
Old Jul 17, 2006 | 03:58 AM
ws6charged's Avatar
mine works perfect not one prob cept a leak but thats my falt stupid paper gaskets
