ARRGGHH differential shaft removal
while attempting removal of the differential shaft, i tapped the shaft in too far.
the long side is out too far to allow rotation of the diff so i can pull the shaft.
i pulled the fill plug and can see the shaft...does anyone have any easy solution to move the shaft back into the diff so i can rotate the diff and pull out the shaft?
