Just installed TA Performance Rear Diff Cover
Old Jul 19, 2006 | 06:51 PM
Michael02hawk's Avatar
Default Just installed TA Performance Rear Diff Cover
All went well, studs and all. All the bolts fit fine.
My only question is, we couldnt get the heat shield to mount up properly above the cover.
The TA cover has some molding running accross the cover, which interfears with the heat shield. Where are the original cover does not have any molding running into the outer bolting area.
My original cover came with the firehawk, as part of SLP's auburn rear diff package. Its not thier cooling cover that is sold aftermarket tho. So Im not even sure if this heat shield originally came GM or as part of the SLP stuff?
anyone else run into this?
Old Jul 20, 2006 | 07:54 PM
GIJosh's Avatar
Heat shield? Do you mean for the exhuast?
Old Jul 22, 2006 | 09:26 PM
Giddswat's Avatar
I just did a TA cover on my 2002 Z28, and I had the same heat shield(held by the top three bolts) I just left it off, so far no problems.
Old Jul 23, 2006 | 09:01 AM
HavATampa's Avatar
Question
What is that shield for? I took mine off a few years back and never could figure out what purpose it served. Is this the one you are talking about?
Old Jul 23, 2006 | 10:15 AM
mcamp001's Avatar
it seems like that is more of a shield for the brake lines not specifically a heat shield. I left mine off also, no problems
