Any regrets with gears?
Everyone seems to like the upgrade, most complaints are just on how they've done it.
If you are going to a 3.42, swapping whole rear ends is the way to go, but since yer going to a 3.73 you will have to swap the gears and not just a rear.
Try dropping your car into 3rd and running at the RPM you'll be cruising at in 4th with the new gears. See if the noise drives you nuts. If it does then you should take that to heart.
