Need some help
Old Aug 14, 2006 | 06:32 AM
efirdj's Avatar
Default Need some help
I have a Strange 12-bolt with 4.11 gears and 33 spline axles with a spool. i have come to the conclussion that a spool just isnt what i want/need so i want to do a swap to a locker. my problem is, is that i cant find a locker that would fit. i was looking really hard at the ECTED Electronic Controlled lockers by Auburn, but, as i said, i cant find one to fit my application. Strange said you cant put a locker in it. but i think thats because they dont make one for an fbody, and they dont want anyone putting non-Strange parts in. can someone point me in the right direction?
Old Aug 15, 2006 | 10:34 AM
efirdj's Avatar
yep. still need help...
Old Aug 15, 2006 | 01:48 PM
keliente's Avatar
I would try PM'ing a sponsor like Bob @ Exotic Performance plus, or Scott @ Driveline solutions. Those guys would be able to point you in the right direction...all scott does is rear ends, you could call him the rear end guru
Old Aug 15, 2006 | 02:36 PM
YOUNG's Avatar
Detroit-Locker makes several different lockers or limited slips for your rearend. Here is the link to their page that has the information on the new Trutrac for your rearend.
GM 12 Bolt
Designed specifically for car applications
• 33 spline
Tractech Model No. 914A575
4.10 & up “4 series” gear ratio
http://www.detroitlocker.com/newprod.htm
Old Aug 15, 2006 | 03:06 PM
1BadAzzWS6's Avatar
What application are you shooting for? Strip? Street? Both? Weekend Warrior? Daily Driver?
IMO if you plan on driving around town at all then you're best bet is to go with the Tru Trac posi.
