Torque arm for Moser 9"
Old Aug 24, 2006 | 09:07 PM
v8juice's Avatar
Default Torque arm for Moser 9"
What torque arm are you guys using(other than stock) for the Moser 9" that will bolt up without hacking anything up?
Old Aug 25, 2006 | 04:37 AM
EPP's Avatar
EPP
Thumbs up
The Spohn 405 torque arm will bolt right up, and removes the stress on the transmission, as the front mount of the torque arm is placed behind the transmission. The rearward placement of the front mount creates better traction as well. This is a 100% bolt on torque arm, no welding is required. Bob
Old Aug 25, 2006 | 06:15 AM
94Z28Joe's Avatar
I'm using the umi torque arm and it fit perfectly its also the tunnel mount that has its own cross member.
Old Aug 25, 2006 | 07:11 AM
tim99ws6's Avatar
Random Tech TA. Sorry, but chassis mount "short length" TA's aren't my flavor.
Old Aug 26, 2006 | 01:11 AM
CW00BlackTA's Avatar
If you are going for drag racing, you'll want a shorter body mounted TA such as the Spohn or Umi units. I'm running the Spohn unit that Bob suggested above.
Old Aug 26, 2006 | 01:51 AM
SS4Matt's Avatar
I'm running the BMR transmounted one...the only thing i had to do was grind down a little bit of the "sloppy" casting that was on my moser TA mount
Old Aug 26, 2006 | 12:23 PM
tim99ws6's Avatar
That's a MYTH. Unless you are making over 600rwhp, a chassis mounted TA is not needed. They are nice units though!
Old Aug 26, 2006 | 10:47 PM
v8juice's Avatar
The car very rarely is ran at the track so Ill probably go with a basic trans mounted unit. I had a Eldebrock arm that someone gave me that worked on the stock rear but the mounting flanges were not wide enough and no amount of cutting or grinding would help make it fit to a Moser 9".
Old Aug 27, 2006 | 12:50 AM
tim99ws6's Avatar
I modified mine to fit to the Moser 9". That is, i modified the 9" torque arm bracket to get the TA to fit.....then i went to the track and absolutely DESTROYED that edelbrock TA. be careful,they are NOT built to handle what a 9" can handle
Thats why i went to the Random tech
Old Aug 27, 2006 | 11:52 AM
Studytime's Avatar
...but with 600 rwhp and an aggressive launch, I wouldn't want my torque arm anchored to a piece of sheet metal [the "chassis", aka floor]. I went with a UMI arm, and have been happy with the build quality. It's the full length arm, and important to me it's not mounted to the thin metal floor. Being that the fastest cam-only car in the country runs the same design torque arm, I figured it would be good enough for my car.
If you were referencing removing the TA from the tailshaft, then I think that's a great idea! As much as I wouldn't want my TA achored to the sheetmetal floor, I'd want it on my transmission even less.
I especially like the adjustable UMI TA paired up with the adjustable (to change instantaneous center) BMR crossmember that relocates the TA off the tailshaft.
Ben T.
Old Aug 27, 2006 | 04:43 PM
thechef's Avatar
Moderator
i run the BMR tq arm(trans mounted) without any issues
Old Aug 27, 2006 | 08:06 PM
tim99ws6's Avatar
Ben T.
Ben,
I think you and i think WAY too much alike, ahahahaha. I would venture to say a well-built "tranny mount style" TA with the BMR relocation setup is hands down the best TA setup you can run on our cars(minus Madmans)
I've installed a few chassis mount TA's on friends cars in the past, and the thought that the TA is held on by that flimsy metal scares me. Hell, i dont even feel comfortable knowing my SLD DD's are connected through those bolts.
I am aware that the TA will push into the mount on launch, but what scares me is regular street driving, where dynamic road conditions will be much more extreme on that flimsy joint over time.
I think the whole "chassis mount" style is a bit of a fad(sp?), BUT i know there are ALOT of fast cars out there that prove they work.
Regardless, i think just about ANY decent aftermarket TA for our cars is going to improve the car, as long as it is adjustable, and is built heavily enough to handle hard launches.
Old Oct 14, 2006 | 09:07 PM
88GTA's Avatar
Hi,
so, just to recap,
1. stock-type torque arms with the mount relocated to the cross memeber is the best
(ex. spohn 402 or a umi trans mounted with the umi relocation kit )
2. floorboard mounted torque arms are good for high poowered drag racing, but can be bad for the floor boards
(ex. umi tunnel brace torque arm )
3. stock-style torque arm mounted to the transminission are ok too, but not optimal
(ex. the stock arm, and many aftermarket )
is this right?
do the floorboard mounted torque arms mount to the same place as the inside connection on SFCs? If running SFCs, does that make the floorboard mounted torque arms a definate plus over trans-mounted, as the floorboard mounted torque arms are then attached not to the floorboards, but to the SFCs?
Old Oct 15, 2006 | 11:57 AM
UMI Performance's Avatar
Hello,
Anyone of our torque arms to the exception of our non-adjustable set-up will work excellent on a 9", and they fit extremely well with a Moser.
For 600 RWHP I would recommend at some point to get the torque arm off the transmission, whether it be a torque arm relocation kit or a shorter tunnel mounted torque arm. Both will work extremely well, the short arms do help to transfer weight a bit better and will work better on the higher HP cars. The shorter arms do bolt to the floor chassis, we have never had a issue with this but I can see where it could be. That is why we have designed our 3-Point style SFC's. These SFC's bolt under the torque arm front mount and remove the stress from the floor of the car.. a excellent set-up for high HP cars. Below is a few pictures to show different set-ups. If you have any questions please ask and I am glad to help.
Short tunnel mounted torque arm with 3-Point SFC's-
Transmission Mounted torque arm with relocation kit-
Old Oct 15, 2006 | 12:06 PM
marine02ss's Avatar
I got a spohn TA with true duals,no clearance problems
Old Oct 15, 2006 | 06:26 PM
v8juice's Avatar
So is anyone using a nonadjustable TA on a Moser 9"?
Old Oct 15, 2006 | 07:55 PM
I would suggest not to get the non-adjustable if you can afford a adjustable set-up. When installing a 9" it usually takes some adjusting to get the rear end set correctly and to work properly. A non-adjustable arm will really limit your possibilites when it comes to the install, if you get any driveline vibrations ect. the non-adjustable will not let you correct these.. the Moser 9" never falls right in place. Also if you are going to spend that kind of money on a rear end a adjustable unit will really let you get the max performance from the set-up.
If you have any questions please ask. Thank you,
Ryan
Old Oct 15, 2006 | 08:43 PM
v8juice's Avatar
How do you get a vibration in the driveline after installing the Moser 9"? I thought they were suppose to be "bolt in" with no hassle.I have developed a small vibration after 400 miles on my Moser 9" but I thought maybe I need to get my tires balanced. If it is a incorrect pinion angle that is causing the problem then what is the correct angle on an F body that has been lowered 1.25",or is it something else?
