12 Bolt or 9": Which eats more HP?
Old Aug 27, 2006 | 09:07 AM
ssbodyman's Avatar
Default 12 Bolt or 9": Which eats more HP?
I will be doing a rear end change soon and my car makes 428RWHP and 408ft/lbs or Torque. So I am in that wonderfull 12 bolt or 9" debate on which to go with. So my question is, which rears eats the most HP? I have been told that the 9" will chew up to 20HP and the 12 bolt uses only 10 to 12HP. Anyone out there have some dyno #'s or other input?
Old Aug 27, 2006 | 11:46 AM
EPP's Avatar
EPP
It really doesn't matter if the 9 inch uses more horsepower, which I am sure it does. It is a stronger rear and unless you're running in a class where every last horsepower counts, I would go with the 9 inch. Bob
Old Aug 27, 2006 | 11:58 AM
Studytime's Avatar
If you have 3-channel ABS, that you'd like to keep on that '98 it might make the decision a little easier.
Ben T.
Old Aug 27, 2006 | 11:59 AM
Pipelayaz's Avatar
I agree, if you are worried that much about parasitic drivetrain loss go get a CF driveshaft to go with the 9''.
Old Aug 28, 2006 | 07:56 AM
ssbodyman's Avatar
Anyone else?
Old Aug 28, 2006 | 07:58 AM
Ericbigmac83's Avatar
To answer your question, the 9" will steal a little bit more of your hp.....but is stronger......so have fun debating
Old Aug 28, 2006 | 08:28 AM
TeEnAgE pHeNoM's Avatar
Get the 9". You don't have to worry about it breaking.
Old Aug 28, 2006 | 10:09 AM
Nittany_marine's Avatar
The 9" robs a bit more, but its a bunch stronger. Thats why I went with one.
Old Aug 28, 2006 | 10:26 AM
fastcameross's Avatar
ya i broke mine about a year ago..now i have the 9" w/ no worries..didnt really notice any loss in power
