Need an explaination
Old Aug 29, 2006 | 03:27 PM
supersix's Avatar
Default Need an explaination
I am changing my rearend this weekend.....I bought a 95 Z roller that has a Moser 12 bolt in it.....I have an 02 Camaro that has an LT1 rearend.....I have never done a rearend swap before but have decent mechanical skills. I don't have a lift or a jack with a platform on it to set a rearend on. can I just undo the 12 bolt with the tires still on it roll it out from under the car by the torque arm and do the same with mine.....then swap them. Does the suspension need to be totally unloaded. if someone has a writeup on a rearend swap it would be greatly appreciated....Sorry it this is a repost but search won't work
Old Aug 30, 2006 | 02:13 PM
keliente's Avatar
I think that would be more of a pain that it is worth. I don't have a big jack or cradle, I actually unbolted the rear end and set it on two jackstands, then dragged it out from under the car.
Here's a how to.
https://ls1tech.com/forums/showthrea...nstall+12+bolt
