12 bolt help (again)
Old Aug 30, 2006 | 05:53 PM
ChicagoTransAm's Avatar
Default 12 bolt help (again)
Got the drivers-side axle out due to a leak. Just curious, how far down should the bearing/seal be pressed? Here's some pictures...
Old Aug 30, 2006 | 05:56 PM
FWIW, it has leaked from day 1. Had it installed by a shop which will remain nameless. I "think" that this part is a piece from the e-brake assembly, but wanted to make sure
Old Aug 31, 2006 | 02:09 AM
Anyone?
Old Sep 3, 2006 | 04:57 PM
OK... figured out that it is in fact pressed up as tight as it can be... or at least pretty sure. There is no visible damage to the seal or bearing though? So what else would cause this to happen over and over again?
