10 Bolt Pinion Deflection(help!!!)
Old Sep 5, 2006 | 07:16 PM
BREAKPARTS's Avatar
Default 10 Bolt Pinion Deflection(help!!!)
OK SO IM GOING TO TRY SOME NEW STUFF WHEN CHANGING MY GEARS AGAIN..IM GOING TO WELD THE **** OUT OF THE AXLE TUBES THIS TIME,,USE A SOLID PINION SPACER,AND A T/A COVOR--ITS GONNA SPORT 410'S AGAIN----OK I KNOW IT WILL STILL BREAK,BUT I WANT IT TO LAST LONGER THIS TIME---SO HAS ANYONE DONE THESE THINGS AND WILL IT WORK-----MY PROBLEM SEEMS TO BE PINION GEAR DEFLECTION ,SO THE SOLID SPACER AND T/A COVOR SHOULD HELP THE PINION STAY TOGETHER I SUPPOSE---I HAVE AN EATON AND STOCK AXELS--LET ME KNOW IF IM DOING THE RIGHT STUFF
Old Sep 6, 2006 | 10:19 AM
2000TransAmWS6's Avatar
check out the last 2 isssues of High Performance Pontiac
