rearend swap question
thanks, any help is greatly appreciated!
scott
If I recall correctly should you decide to use this differential you will need to pull and mount the reluctor ring from your carrier, swap it over to the new axle, drill a hole in the housing and mount the sensor like it is on your diff.
The axle rings and ABS sensors present on the donor diff won't interfere with anything and I would just leave them alone.
