Need a little help on differential install
Old Sep 7, 2006 | 06:23 PM
airattack111's Avatar
Default Need a little help on differential install
Alright, the limited slip differential came in today. But it's a little different from the open one that came with my v6.
I'll try to explain this the best I can.
On the open diff. you slide it on the axle, slide the c-clips threw the slot, then lock it.
On the posi it's the same way, but when you go to put in the c-clips there's like a plate blocking it or something.
Are there any writeups for this install? thanks
Old Sep 9, 2006 | 01:38 PM
ChicagoTransAm's Avatar
Does your car have TCS? You'll need to pull the sensor out to get the axles to slide in far enough to install the C clips
