lt1 tranny in a ls1 fbody
Old Jun 24, 2002 | 08:18 AM
pontiaddict's Avatar
Default lt1 tranny in a ls1 fbody
anyone know if you can retrofit a lt1 trans (a4)into a ls1 fbody?what would have to be done to make it work? why wouldnt it work?
Old Jun 24, 2002 | 11:12 AM
Kevin Winstead's Avatar
Default Re: lt1 tranny in a ls1 fbody
It'll bolt in there. It's only 3/8" shorter than the LS1 transmission. From 96 on up to present the electronics should be the same. You'll need to use an LT1 converter that has a 3/8" pilot extension and you'll need to drill your flexplate out to the LT1 converter boltpattern, or modify the converter boltpattern to the 11" LS1 bolt circle. Just let me know if we could help you.
Kevin Winstead
TCI Automotive
