Driver side sitting higher after 9"??
Old Sep 11, 2006 | 07:07 PM
Daniel_z28's Avatar
Default Driver side sitting higher after 9"??
After I installed my 9" my driver side is sitting about 1/2" higher than the passenger side?? Anyone know what's wrong. I thought the shock setting might be wrong but I took it off and checked, not the problem.
Old Sep 11, 2006 | 07:19 PM
Daniel_z28's Avatar
Just thought of something, I still have the stock panhard rod and I cut a little off the stock springs, could this be my problem?
Old Sep 11, 2006 | 08:06 PM
SS4Matt's Avatar
could be, i noticed after i installed my 9" the rear of my car in general sat a bit higher...which was sweet, because my car suffered typical F-body booty sag prior..and it fixed that!
Old Sep 11, 2006 | 09:20 PM
todddchi's Avatar
The orientation of the spring/top cushion assembly as well as the spring seated in the top cushion can make a little difference.
I am going through this right now after a 10 bolt to 10 bolt swap, my right rear was sitting a good inch lower, if not more. A portion of that was fixed by changing the spring/cushion orientations around, I believe the rest is attributed to a shock that may have been damaged during installation.
I left the 10 bolt hanging by the shocks at the last stages, and the right rear shock got torqued on pretty badly. I believe it lost some fluid, and people here have said a bad shock will be just enough to drop that corner slightly. If you lift up on the rear you'll find it doesn't take much force to correct for a half inch or so.
The right rear shock takes the most abuse, and decarbons aren't exactly very durable in the first place.
Many people claim this is normal, or a common feature, but mine started doing it after the rear end swap, so something is up.
For the time being I have a couple little spring boosters in place to hedge it up level.
I'll post up if the shocks work.
Old Sep 11, 2006 | 10:40 PM
Daniel_z28's Avatar
Thanks, I'll check the springs. I like the way the passenger side is sitting I just want the driver side to come down 1/2" or so to match. I don't think It's my shocks, they were cheap competition engineering shocks but they are new.
