Spool Gears
Old Sep 16, 2006 | 08:22 PM
canadaisintexas's Avatar
Lame Excuse for a Photog
Default Spool Gears
Car i just bought has a spool and 4.10's. I want to switch to 3.73's and keep the spool, do i have to get gears specially designed for a spool? Im not sure if the spool is built in to the gears or really how it works because until this car id never even heard of spools before since i come from the world of rx7's and none of them do it that i know of.
Thanks guys,
Rob
Old Sep 16, 2006 | 08:41 PM
Jditlfm's Avatar
No you can get the 3.73's and not have to worry about a diffrent spool, you will be fine.
Old Sep 16, 2006 | 09:32 PM
mzoomora's Avatar
14 Second Truck Club
If it is a 12 bolt the spools are different for a 3.73 and a 4.10, unless you get a thin gear 3.73 or have a thick 4.10. If it is a 9", or a 10 bolt with a mini spool you are fine.
Old Sep 16, 2006 | 11:12 PM
It's a strange 12 bolt So what kind of gears should i be looking for?
Old Sep 17, 2006 | 09:38 AM
mzoomora's Avatar
Richmond 49-0096-1. It is a 3.73 gear for a 4 series case/spool (thin gear). I am pretty sure they are the only people making it.
