which yoke
Old Sep 22, 2006 | 01:03 AM
SLP4CamaroSS's Avatar
Default which yoke
which yoke do i need for the 9inch for my m6 ls1 camaro
Old Sep 22, 2006 | 08:05 AM
richieg's Avatar
I used a 1330 series ujoint size, close enough to 3r to work fine. It lasted me 50k miles until I changed to a different setup. Keep in mind though that you will need a long pinion yoke (overall height right around 5 inches) The standard one is too short at 4 inches to work with the factory driveshaft.
Old Sep 22, 2006 | 02:09 PM
CW00BlackTA's Avatar
The 1350 yoke is the heavy duty version that most people get for the strength. You'll need to buy a cross-over u-joint from NAPA or such to connect to the stock drive shaft.
