Part number for u-joint for 9inch?
Old Sep 22, 2006 | 07:08 PM
SPRAYED 01's Avatar
Default Part number for u-joint for 9inch?
Ive done a search and the only part numbers i can find are the conversion numbers for using a stock d/s. I need one that has caps the same size as the 1350 yoke on all 4 ends. If any one has a napa number that would be awsome. Thanks
Old Sep 22, 2006 | 10:43 PM
SPRAYED 01's Avatar
if anyone has any info it would be greatly appreciated. I need to pick this u-joint up tommarow but dont know the part number.
Old Sep 23, 2006 | 01:49 AM
SLP4CamaroSS's Avatar
1350 Conversion U-Joint (Napa Part # 240-0447)
Old Sep 23, 2006 | 07:02 AM
sprydncamd ta's Avatar
i got mine from summit it was prescision part number 447
Old Sep 26, 2006 | 11:42 AM
93TAWicked1's Avatar
The 1350 at Napa I gave them that Precision number 447 and a Dana Spicer number 3-94-18x for the ubolt kit.
Old Mar 21, 2013 | 11:39 AM
93camaro_zzz's Avatar
Just want to update this thread to state that the Precision 447 joint is no longer the correct part number for a U-joint with 1350 all the way around... The 447 has 1350 on two and a Saganaw 44 on the other two. The saganaw 44 is a smaller size and would not work.
The correct NAPA part number now for 1350 on all 4 sides is Precision #331. I just purchased this joint and installed it. Working great so far!
