PLEASE HELP!!!
Old Jul 1, 2002 | 01:55 PM
MIGHTYMOUSE's Avatar
Default Re: PLEASE HELP!!!
unless you are loosing fluid, you have a case of backed out pressure plate bolts..
did you torque them to 55#'s with red loctite?
Old Jul 1, 2002 | 04:31 PM
BLK00TA's Avatar
also when i put the car into neutral and pump the clutch the clutch will get hard and then its pretty easy to put it into gear.if i dont do this then its a bitch to put into gear.
Old Jul 2, 2002 | 12:09 AM
BLK00TA's Avatar
Default PLEASE HELP!!!
about 2 weeks ago i put in a ram cluctch with the updated gm hydraulics in my ram air. well after about a week the clutch pedal feels soft and when i go to shift into a gear it seems like the clutch isnt disengaging at all and its hard as hell to put it into gear.also when i have it in first and i push the clutch down and rev it the car starts to move.is this my slave or master cylinder acting up. i bled the slave and there is no air in the system.or just maybe is my slave cylinder bad. please help
Old Jul 2, 2002 | 07:22 AM
Stick only's Avatar
Sounds like a bleed issue to me. If pumping it up helps, try having the system power bled.
Old Jul 2, 2002 | 10:29 AM
BLK00TA's Avatar
HOW DO I POWER BLEED THE SYSTEM.BEFORE I WOULD PUMP THE PEDAL THEN OPEN THE VALVE.ETC.ETC.
Old Jul 3, 2002 | 07:01 AM
Stick only's Avatar
Power bleed would have to be done by a shop that has the equipment. Also, the 'mighty-vac' vacuum bleeding system works good.
